查看: 20992|回复: 85
Real Flight G4 (更新扩展包和新版的EMU v3.2)
发表于 2008-4-15 23:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
种子连接是Mininova的,实际上是Demonoid发布的,下完的朋友多多做种。
Emu版本是3.1,md5值:DAE9883BC239C1849DA17B5DCD4A47E0
G3和G4的Key包括在说明文件里。
有朋友找不见Key,这里帖一下:
RFG4 Serial: 01113084-G4-3611193964
Interlink Elite Controller Serial: 3987906-I3-399835
NFO信息:
种子下载:http://www.mininova.org/tor/1318329
Emu下载:http://www.mininova.org/tor/1325520
不想用BT下载emu,我传了网盘:
http://www.filefactory.com/file/f8c8ed/
去官网看了下,有免费的Add包下载。
原地址:http://www.realflight.com/free-g4-add-ons.html
RealFlight Add-Ons Volumes 1 & 2 now
available FREE for G4 users!
RealFlight Add-On 1 & 2 have been reworked for use with RealFlight G4. Even better, they are now available as free downloads! Numerous technical issues prevent the original Add-On disks from working with G4, but because we want G4 users to have access to this content, we're giving it away! The aircraft have been re-trimmed and the airports have been tweaked to look more like the original G1/G2 versions of RealFlight. Also, in cases where we updated an AO1 or AO2 aircraft (e.g. the Piper Cub) and made it a RealFlight G4 aircraft, the old version does not appear in the repackaged Add-On. All of the Add-On content is otherwise unmodified.
The repackaged Add-On volumes are only compatible with G4 version 4.00.051 or later. They will not work with RealFlight G3/G3.5, which already fully support the original Add-On disks (still available for purchase). This content is released as-is and we do not plan to make any further changes to it. To update G4 to the current version click the "Additional Options" tab from G4 Launcher.
Add-Ons 3, 4, and 5 will also be re-packaged for G4 and released for free when they are ready.
此Add包仅支持4.00.051或者更新的版本,不能用于G3或者G3.5,请大家注意。
安装方法:
用WinRAR解压缩文件,把解压缩得到的文件,复制或移动到“C:\Program Files\RealFlightG4\Data”中,这里是默认位置。根据你自己的G4安装的盘符路径来复制,然后再启动G4,在飞机和机场选项里就会出现新添加的机机和场景了。
更新一个新种子,包括了RealFlight G4 + 2 Addons + Dongle v3 1 + Update 4 00 051,一次搞定。
Realflight G4 Dongle Emulator v3.2 Supports Expansion Pack 5
新版的Emu,可以支持最新的扩展包
RealFlight Expansion Pack 5
新的扩展包增加以下的飞机:
This is the RealFlight Expansion Pack 5 from Great Planes.
**Compatible only with RealFlight G4.**
FEATURES:
Adds 18 new aircraft-10 Airplanes, 3 Seaplanes, 4 Rotary Wing (3 Helicopters, 1 Autogyro), and 1 Amphibious Aircraft (Flying Hydroplane) Three new flying sites
Airplanes:
Airliner
Great Planes Sukhoi SU-31
ElectriFly Reactor Bipe
Top Flite P-51 Mustang
Krill Katana
Great Planes 38% Extra 330S
Scale Sailplane RF-97
Great Planes P-40 Warhawk
Douglas A-4 Skyhawk
ElectriFly Pluma Bipe
Seaplanes:
Republic SeaBee
De Havilland Beaver
Dornier Do-24ATT
Helicopters:
AH-64 Apache Helicopter
Align T-Rex 500 EP Helicopter
Autogyro
Synergy N9 Helicopter
Amphibious Aircraft:
Death Foil (flying hydroplane)
Flying Sites:
Sub Base - 3D
Obstacle Course 6 - 3D
Photofield Superstition Airpark
“5iMX 眼尖为实,找图快乐”活动——12月29日期,本图片为活动图片,与主题无关
发表于 2008-4-16 00:26 | 只看该作者
顶了,这个emu应该没问题,但是偶的显卡不行,只好忍了,多谢lz,大家又有免费的玩了
发表于 2008-4-16 04:00 | 只看该作者
:em26: :em26: :em07: :em07:
 楼主| 发表于 2008-4-16 09:23 | 只看该作者
原帖由 xuzhaohuatom 于 2008-4-16 00:26 发表
朋友拿什么控玩的?!集成显卡估计玩G4会很卡....
以前的Intel的集成显卡不支持DirectX9.0,连游戏都进不去。
[ 本帖最后由 awheel 于 2008-4-16 18:56 编辑 ]
发表于 2008-4-16 10:49 | 只看该作者
前天看到一个和安装打好包的,下了三天还没有下载完,有单独的更好了
G4早就下好备用了,不知道G4 service Pack1-4 哪里有下?
发表于 2008-4-16 14:47 | 只看该作者
我的电脑也不能玩
发表于 2008-4-16 15:22 | 只看该作者
支持免费的:em26:
发表于 2008-4-16 15:38 | 只看该作者
不错,挺好
发表于 2008-4-16 17:48 | 只看该作者
回复 #4 awheel 的帖子
用lama的控玩,是855gme的集成显卡,玩g3都没问题,听说g4 要求更低,可是玩不了,查了下,好像是对d9的兼容性不好
发表于 2008-4-16 17:50 | 只看该作者
我的就是这问题
- Loading Errors:
Sometimes when the game tries to load it throws ugly errors saying "Error creating effect xxxx"
or something similar and halts, it can be right on the start or after 180 elements or so ...
This is caused by your Video Card Adapter that is not 100% compatible with DirectX 9.0c.
Check out: http://12.156.2.54/forums/showthread.php?t=9243 or seek google for this error.
You will need a quite newish card in order to run this simulator.
If you still want to to overcome this problem you can try and select the
"Try to overcome loading problems" checkbox in the Emulator this may actually work in some
cases but not guaranteed.
Sometimes using this flag can just hang the game when it is trying to load :/
 楼主| 发表于 2008-4-16 18:55 | 只看该作者
原帖由 xuzhaohuatom 于 2008-4-16 17:50 发表
我的就是这问题
- Loading Errors:
or something similar and halts, it can be right on the start  ...
看这句:This is caused by your Video Card Adapter that is not 100% compatible with DirectX 9.0c.
说明你显卡不支持DX9.0,XD什么显卡啊?
发表于 2008-4-16 19:26 | 只看该作者
顶一下!!!!!!! 谢谢楼主了
发表于 2008-4-16 19:51 | 只看该作者
太好了,我下过G4,可是没有EMU。这下好了,试试这个EMU,多谢楼主,
不知道怎么做种,一会上百度查询下、学学
 楼主| 发表于 2008-4-16 19:55 | 只看该作者
原帖由 王立刚 于 2008-4-16 19:51 发表
不知道怎么做种,一会上百度查询下、学学
Emu的txt文件里有G4的Key。
用BT下载软件,下载完以后,只剩下上传就是在做种了。:em15:
发表于 2008-4-16 20:02 | 只看该作者
回复 #11 awheel 的帖子
是intel855gme的集成显卡
 楼主| 发表于 2008-4-16 20:09 | 只看该作者
原帖由 xuzhaohuatom 于 2008-4-16 20:02 发表
是intel855gme的集成显卡
那就是显卡的问题了,硬件不支持DX9.0。
发表于 2008-4-16 23:14 | 只看该作者
感謝樓主,試了一下EMU可開啟G4,還在試Channel 設定.
发表于 2008-4-17 00:34 | 只看该作者
先谢过了!
发表于 2008-4-17 00:54 | 只看该作者
这个EMU 3.1 还是有限制的,直机的悬浮训练 和 固定翼的吊机训练无法使用
发表于 2008-4-17 00:56 | 只看该作者
怎么输不了key呀,总是提示key无效或丢失?!
