查看: 6623|回复: 22
我也发个云台吧,国外的,简单实用,大家可以自己造
发表于 2008-8-1 10:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
发表于 2008-8-1 11:09 | 只看该作者
这个论坛很恶心
发表于 2008-8-1 12:30 | 只看该作者
原帖由 allegro 于 2008-8-1 11:09 发表
这个论坛很恶心
你说话好酷哟,来这儿找恶心的?你的爱好很特别哟。
发表于 2008-8-1 12:53 | 只看该作者
ri***是虾米????
发表于 2008-8-1 17:14 | 只看该作者
发上来就是了!看图说话
TS2-Pod kitStarting at: $40.00
Please Choose: Pan & TiltKX191( more powerful HS81 servo for pan) ( +$10.00 )
KX131/KX171
KX151
Add to Cart:
The EZ Pod kit is the best way to convert your stock Multiplex Twinstar 2 into an FPV airplane. No modification to the airplane is required. The TS2 Pod snaps into the stock canopy holders.
The kit is precisely laser cut from plywood. You can assemble the kit rapidly, in 15 minutes with superglue.
Camera and transmitter not included. Be sure to select your camera( KX131/KX171 or KX151) when ordering the EZ- Pod.
Purchase includes :
- Plywoord parts
- Pre-cut 1/16" SS rod (2)
- Dubro Dura-Collars 1/16" (4)
- Dubro EZ connector
- Rare Earth Magnet - Disc - D0.125 x T0.063 (10)
- M2x8 brass screws and nuts (4)
- 9 gram servo (2)
TS2 Assembly Instructions.
1. Pan and Tilt Assembly
Glue the two smaller pieces evenly to create a 2mm slot
Glue the top piece. Avoid getting glue in the middle slot.
Make sure there is no glue residue in the axle slot.
You may mount the camera to the assembly using double sided table.
Cut the servo tabs away fom ONE servo. This servo is used for tilt.
Glue the tilt servo to the previous assembly, as shown
Trim the servo arm to fit the 'Pan' base. Screw the servo arm to the pan base. Epoxy is recommended to reinforce the connection between the servo arm and pan base.
3. Final Assembly:
Mount the camera to the pan and tilt assembly with stainless steel rod and collar
Assemble the servo arm connector.
Use collars to secure the stainless steel rods.
发表于 2008-8-1 17:42 | 只看该作者
学习了
发表于 2008-8-1 19:00 | 只看该作者
精致  学习了 动手能力强的  就可以仿照```
发表于 2008-8-1 19:23 | 只看该作者
不错,可以仿制
发表于 2008-8-2 00:18 | 只看该作者
赞一个!学习以后制造。
发表于 2008-8-2 13:34 | 只看该作者
这种设计唯一不好的地方就是俯仰舵机是安装到了摄像头上了,舵机引脚线还得留个活动的余量,这样显得线很乱,不紧凑
发表于 2008-8-7 16:10 | 只看该作者
这个还用学?
发表于 2008-8-12 01:10 | 只看该作者
学习
发表于 2008-8-12 16:10 | 只看该作者
值得顶你一下!
发表于 2008-11-24 22:06 | 只看该作者
好东西
如果有尺寸就好了
发表于 2008-11-25 01:15 | 只看该作者
呵呵不错好东西啊~
发表于 2008-11-27 10:49 | 只看该作者
好 可以仿制啊
发表于 2008-12-17 00:11 | 只看该作者
学习一下
发表于 2008-12-17 08:07 | 只看该作者
不错 不错
发表于 2008-12-17 08:53 | 只看该作者
仿制是中国的强项,支持!
发表于 2008-12-18 10:15 | 只看该作者
休斯那里就有卖的啦
