查看: 1931|回复: 14
G4升級G4.5
发表于 2008-11-4 03:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
G4升級G4.5找了好久終於找到了!!
分享給大家~~:em05: :em05:
http://www.realflight.com/updates2.html
参与人数 1威望 +2 收起 理由
论坛老模友 + 2 精品文章
发表于 2008-11-4 07:41 | 只看该作者
顶!沙发!
发表于 2008-11-4 08:05 | 只看该作者
我还用我的areofly,g4电脑吃不消啊.
发表于 2008-11-4 08:08 | 只看该作者
帮楼主贴出来,直接点了就下了:
Download Options
For your convenience, there are multiple ways to upgrade your RealFlight G4 to G4.5. Please note that the upgrade file size is large and may take a while to download. The different methods to obtain the upgrade include:
  • RealFlight Launcher
    Clicking the RealFlight G4 icon on your computer opens the RealFlight Launcher. Instead of clicking Run RealFlight, click the Additional Options button. Then click Registration/Updates button. A new window will appear that will allow you to register and update your RealFlight simulator. Simply click Update to Latest Version and follow the on-screen instructions.
  • Download the Upgrade File
    If you prefer, you can download a self-installing upgrade file from here:
    RealFlight4_50_021.exe - 987 MB
    Download this file and run it on the computer which RealFlight G4 is installed.
  • Burn your own Upgrade DVD
    If you prefer to download the upgrade on a different computer than the one RealFlight G4 is installed on, or if you wish to share the upgrade with other G4 owners, you may want to choose this option. If you have a DVD burner, download the following disc image:
    RFV4UP_4_50_021.iso - 988 MB
    Burn this to a DVD using your DVD writing software. Once this DVD is created, insert it into the computer that has RealFlight G4. This disc will autostart and begin the installation.
发表于 2008-11-4 08:39 | 只看该作者
emu 3.2 支不支持这个版本?
发表于 2008-11-4 08:48 | 只看该作者
是啊,不支持!等支持的Emu
发表于 2008-11-4 09:22 | 只看该作者
硬狗直接支持, EMU还要少等
有动手能力的同学改一下程序的版本号,就可以支持
发表于 2008-11-4 15:19 | 只看该作者
等等看:em15:
发表于 2008-11-4 16:11 | 只看该作者
http://www.knifeedge.com/forums/showthread.php?p=132730
已经4.50.025了, 在线升级即可
发表于 2008-11-5 01:34 | 只看该作者
025 是beta的
发表于 2008-11-5 10:22 | 只看该作者
支持,顶
发表于 2008-11-5 11:11 | 只看该作者
好东西!
发表于 2008-11-5 11:21 | 只看该作者
哈哈~~又有新机种玩了~~
谢谢LZ
发表于 2008-11-5 11:22 | 只看该作者
都是宝贝!支持!
发表于 2008-11-5 13:45 | 只看该作者
:em26:
