查看: 1632|回复: 16
自己找到了,呵呵,转过来凑活看吧
发表于 2009-8-17 17:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Specs
Auw: 28g
Empty weight(no battery) 25g
Wingspan: 16.5"
4 channel, rudder, elevator, ailerons
servos: Falcon 1.6g (1.7g with connector)
BA 2.5g servo for ailerons
Airframe: 2 mm EPP foam, silkscreen printed 6.8g
ESC: XP-7a lightened to 2g
Motor: AP03 3.17g outrunner including mount 45g of thrust
Prop: 4025
Battery: 140mah 1 cell lipo 20c
Depron foam suport structure
zbends
carbon bracing for leading edge of the wing, wing support, pushrods
tail support
control horns, servo arms (plywood)
motor mount (plywood)
2s Version:
Comes with 2s lipo and C05 motor
Weighs approximately 6 grams more
More power, but not as floaty or slow, works with spektrum Ar6300 no mods
Because this plane is micro and 3d, it is meant for intermediate and advanced pilots. Those who have worked with
micro components and 3d foamies, and flown a little 3d.
This plane is about the same size as the Parkzone Micro Citabria.
It is meant for casual 3d flying in your garage,
backyard, hover practice in your house, etc. It is small enough
to fly in very tight spaces.
This plane will come as 3 different versions.
Receiver ready, with everything listed at the top, as a kit to be used with your own equipment, or it can be used with the new Parkzone 4 channel equipment.
We chose EPP foam to make it one of your longer lasting planes
in your fleet. After bashing it in the living room a bunch of times without a ding on it, I can see how important EPP is for a plane like this!
发表于 2009-8-17 17:55 | 只看该作者
:em26: 呵呵
发表于 2009-8-17 17:57 | 只看该作者
这么小~我还以为是LZ D的
发表于 2009-8-17 19:34 | 只看该作者
经典
发表于 2009-8-17 20:53 | 只看该作者
我喜欢小固定翼
楼主如果知道哪有卖的,麻烦您给我发个PM告诉下。谢谢啦!
发表于 2009-8-17 21:07 | 只看该作者
很喜欢,不知哪里有卖的,那个ar6300还真没见过呢:em26:
 楼主| 发表于 2009-8-18 01:50 | 只看该作者
这些设备除了1.6G的小舵机外  ,其他国内都有卖的!
发表于 2009-8-18 09:19 | 只看该作者
大概多少钱?
发表于 2009-8-18 09:43 | 只看该作者
好东西啊
发表于 2009-8-18 10:53 | 只看该作者
好东西啊
这么小的KT能飞特技吗?
发表于 2009-8-18 12:05 | 只看该作者
好迷你哦
发表于 2009-8-18 12:10 | 只看该作者
看过这机的吊机视频,室内飞很灵活
发表于 2009-9-13 00:05 | 只看该作者
飞机不错,国内国外对待小飞机的态度是不一样的.
发表于 2009-9-16 13:02 | 只看该作者
好漂亮 哪里有卖了?
发表于 2009-9-16 14:37 | 只看该作者
原帖由 转速 于 2009-9-13 00:05 发表
国人喜欢大家伙。汽车都要加个L才好卖。
发表于 2009-9-16 23:22 | 只看该作者
好象买不到小配件,要不就是小配件厂家不愿意做赚不到钱
发表于 2009-10-14 11:37 | 只看该作者
好东西啊
