Easy to use, with MORE functions, for MORE applications...the Triton charger from ElectriFly sets new standards in charger technology! Like many units, the Triton can peak charge NiCds and NiMH batteries, with fully adjustable current rates. But the Triton has the flexibility to do so much more — and satisfy the charging needs for a wide range of R/C modelers — making it the only charger you’ll need!
Handles 1-24 NiCd or NiMH cells, 1-4 lithium-ion cells, or 6V, 12V and 24V lead-acid batteries.
State-of-the-art programming combines simplicity and sophistication — it’s super-simple to scroll through the logically arranged menus with the rotating dial.
Recalls data for up to 10 full cycles, and features adjustable peak detection sensitivity.
Can store up to 10 different battery configurations, for instant, easy recall and charger setup.
Optional battery temperature monitoring (sold seperately-LXDAM4) allows you to safely and accurately charge heat-sensitive lithium-ion and NiMH batteries.
A built-in cooling fan improves charger efficiency and extends the life of the unit.
Small and lightweight, with a durable aluminum case.
Comes equipped with panel-ready banana jacks.
Backed by a full 1-year warranty. |
