查看: 1795|回复: 6
鳳凰模擬加入自己喜歡的機子
发表于 2010-7-4 12:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
http://www.phoenix-sim.com/technical_modelImages.htm~
可以用相機錄製自己的機子,再將檔案寄到鳳凰那裡,請他們製作模型,可以在鳳凰裡面玩~
发表于 2010-7-4 22:11 | 只看该作者
自己做的kt板机可以不:em15:
 楼主| 发表于 2010-7-4 23:11 | 只看该作者
任何自己喜歡的搖控飛機/直昇機,都可以作~
发表于 2010-7-5 00:03 | 只看该作者
这么爽:em26:
连接打不开:em23:
[ 本帖最后由 wuzhibiao 于 2010-7-5 00:11 编辑 ]
发表于 2010-7-6 11:38 | 只看该作者
:em17: 行不行?如何搞。。
 楼主| 发表于 2010-8-15 03:13 | 只看该作者
原帖由 wuzhibiao 于 2010-7-5 00:03 发表
这么爽:em26:
连接打不开:em23:
連結可以打開的 ~
 楼主| 发表于 2011-2-10 09:08 | 只看该作者
~ 網頁無法開起 參考這裡 ~
Model Images
If you own a model which you feel should be represented in Phoenix, and have access to a medium-quality (5 megapixel or above) digital camera then you can take the images which our modelling team need to create your model yourself.
Taking the required images vastly speeds up the time taken to create your model, and will mean there is a much better chance of your favourite model appearing in Phoenix.
General photography tips
The conditions in which you take the images of your model are very important to create the most realistic results.
Currently we recommend that you take all photographs outside in sunlight, as this both negates the need for a flash (which usually results in severe highlights and reflections), and also gives the most natural realistic lighting of the model for use in the simulation.
You should position the model so that the sun is located behind you and the camera, facing the model for best results.
Please take all images in the highest quality possible, as this produces the best results when texturing the finished geometry.
Required images
In order to accurately model and texture the aircraft which you are submitting, there are several important images that are needed by our modelling team:
The main 6-view images
The most important images are the main 6 views. These images must be taken as if the model were a solid box, with each image taken facing directly at the appropriate face of the imaginary box.
An example of appropriate 6-view images would be as follows:
These images are the same for both helicopters and fixed-wing models. When dealing with helicopters with detachable canopies, the following images should also be taken in order that the inner workings can be accurately modelled:
Extra images
In addition to these 6-view images, the following images are required in order to complete the modelling process:
Submitting images
Once you have all of the required images, you can submit them by email or CD-ROM to our modelling department.
If you are sending them via email you will need to zip the images into an archive, and split the images between several emails of around 5 MB each to be accepted by your email server.
If you are sending your images via CD-ROM please let us know at aircraft@phoenix-sim.com for more details.
If you have any other questions or comments please contact us at aircraft@phoenix-sim.com.
[ 本帖最后由 技嘉 于 2011-2-10 09:10 编辑 ]
