查看: 991|回复: 8
LOGO600 SE的问题
发表于 2011-1-22 10:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大家是都用10S的电池吗?如果选择套机里德电极电调!
发表于 2011-1-22 11:05 | 只看该作者
套机里的电机已经换成 pyro 700-450 用12s电飞
如果电机是 700-52的话需要用10s电飞
发表于 2011-1-22 12:35 | 只看该作者
学习了:em05: :em05:
发表于 2011-1-22 15:02 | 只看该作者
套机是700-45的:em05:
 楼主| 发表于 2011-1-22 16:17 | 只看该作者
多谢赐教,再多嘴问一句,套机里的电机比天蝎星4035-560KV怎么样?
发表于 2011-1-22 16:39 | 只看该作者
回楼上,py电机性能没得说。
发表于 2011-1-22 16:51 | 只看该作者
Kontronik官方网站
http://www.kontronik.com/index.php?option=com_content&view=article&id=48&Itemid=83&lang=en
In 3D helicopter flight a motor is heavily used. And it is exactly for this reason that a PYRO is well - equipped.
It's special design and construction make it handle a continuous power of 3,000 W and a maximum of 5,000 Watt for 1 second.
To achieve this a high-quality Neodym material was used for the magnets heat resistible up to 150 °C.
The winding is made of an extremely heat resistant copper, normally used by the aerospace industry.
The rotating can additionally gets a precise balancing. So the thin section bearing is rendered unnecessary.
A continuous power of 3 kW produces a lot of heat even in such an efficient motor as the PYRO. A new designed cooling stream enables the PYRO to release the heat absolutely reliably.
The PYROs are only available in specialised shops or can be purchased directly at KONTRONIK.
The PYRO in short:
  • Neodym magnets, heat resistent up to 150 degree C
  • Specialized wire, heat resisten up to 300 degree C
  • Perfectly balanced
  • Optimized metal sheets
  • Optimized ventilation
[ 本帖最后由 kevin401 于 2011-1-22 16:53 编辑 ]
 楼主| 发表于 2011-1-22 23:51 | 只看该作者
太专业了,欣喜!就是它啦,我也高档一把!
发表于 2011-1-29 18:39 | 只看该作者
原帖由 liurui33 于 2011-1-22 23:51 发表
您啥时候低档过啊??:em15: :em15:
