查看: 2430|回复: 17
MB 设置用软件发布啦!!-更新:这个软件主要是调节两个附加功能
发表于 2011-3-10 10:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
http://www.beastx.com/service_software.html
无意间去网站看看,竟然看见传说中的软件面世啦,大伙尝尝鲜吧,哈哈
我看了一下说明,这个软件主要是调节两个附加功能。并不是想象中可以替代摇杆来设置MB的,不过总还是说明MB公司在努力研发噢。更全面功能的设置软件指日可待哦!!
BEASTX Micro Settings
This tool allows you to set the following additional functions:
  • virtual swashplate phasing for scale models with multiblade rotorheads
  • torque pre compensation of the tail rotor system (RevoMIX)
So concerned are point H in the setup menu (swashplate setting) and point F in the parameter menu (RevoMix).
The values can then be activated by selecting "LED off" at the specified adjustment point retaining the other presets and it can always be switched between the software created values and the presets.
Installation instructions:
Install the file SetupMicroSettings.msi (<- right click - Save target as ..) as usual on your computer. After installation you can start the software by clicking the icon "BEASTX Micro Settings" on your desktop.
The software assumes that the driver for the USB2SYS interface is correctly installed on the system. This driver comes with the update software. So before use install the update software respectively install the included interface drivers there. You also need to know the COM port the interface uses to communicate with the computer. For more information, please see: http://www.beastx.com/showthread.php...r-Step-by-Step especially Step 4.
Usage of the software:
Plug the USB2SYS interface into a USB port of your PC. Connect the interface with the SYS-port of the Microbeast. Turn on transmitter and receiver and make sure that when using an electric model the engine can not start accidentally. Now select in the most top button the COM port that the USB2SYS interface is assigned to and press "Connect" if applicable . Now your Microbeast's data appears in the upper third. Note that BEASTX Micro Settings only is compatible with firmware version 2.0.0 and above!
The lower pane displays the adjustable settings for the two points H and F. There in the upper right corner of each you can see if using these values has already been activated (set to "LED off") in the Microbeast. In this case it says "Enabled ". If you have not already done so you can rectify this now by clicking on "Enable this setting". This is not absolutely necessary but so you can see immediately the effect of changing the settings in the software. The settings can also be performed and saved without activating their usage in the Microbeast unit.
The values can be typed in directly or can be increased or decreased ny using the arrows. In the bottom left status bar it is displayed if a value is written to the Microbeast - "Written successfully".
Note: While the Microbeast is connected to the software you can not make any adjustments at the Microbeast by hand! The button is locked during this time. If before the connection you entered one of the menus this will be automatically exited. The setting of the point at which you are currently will not be stored if it has been changed recently!
Since the menu items are self explanatory here just a few short notes:
  • When using the RevoMIX the tail rotor must compensate load of the main rotor system. So on a helicopter with clockwise turning main rotor therefore if you enter pitch (both positive and negative!) the tail rotor must turn to the right. This also applies to cyclic movements of roll and pitch independently of the direction. Whenever torque is built up the tail rotor must compensate with anti torque. At 0° pitch of the tail rotor makes the least deflection.
  • Experience has shown that a ratio of 1:2 between cyclic and collective pitch is a good guide. For example 15 cyclic and 30 collective Pitch. Then slowly increase to the optimum values. This presupposes that the tail rotor (sensitivity and heading lock proportion) are were adjusted to the optimum extent before. The RevoMIX is only an aid to improve the performance of the tail gyro for example when the tail rotor system is slightly undersized but not to conceal a poor control at all (if without RevoMix when giving pitch the tail turns away desperately you should check the mechanics and tail gyro adjustment instead of trying to compensate with an extremely high RevoMIX value).
  • Asymmetry is a compensation function if the rudder moves unequally in both directions (there are no negative values since the value depends also on the setting for the main rotor torque). Under normal circumstances it should not be necessary to use this - default is 0.
To the scale pilots: It is assumed that the helicopter was adjusted according to the instructions and collective pitch center stick position corresponded to 0° pitch during the setup procedure! A subsequent change of the pitch curve then represents no problem but if from the beginning instead of 0° the adjustment has been done with hovering pitch the RevoMIX can not be used because it assumes that 1500μs pulse on the collective corresponds to 0° of pitch.
[ 本帖最后由 xushg 于 2011-3-10 14:18 编辑 ]
发表于 2011-3-10 11:23 | 只看该作者
:em26:
发表于 2011-3-10 11:40 | 只看该作者
beastx.hk公布中文说明书已经制作完成。购买行货的用户都可以拿到~:em24:
期待beastx.hk协助制作中文版软件。:em00:
详细请看:http://www.beastx.hk/index.php/archives/306
[ 本帖最后由 火星先生 于 2011-3-10 11:47 编辑 ]
发表于 2011-3-10 11:49 | 只看该作者
这个MB实在太惹人喜爱了,还有中文说明书,等有米,真想搞一个!
发表于 2011-3-10 12:02 | 只看该作者
这个期待很久了!
就是不喜欢用按键调试,虽然现场带个notebook也不太方便,不过MB可以装到JJ的肚子里去了。
应该是windows的OS吧,如果有iphone的就更完美了!
发表于 2011-3-10 12:14 | 只看该作者
好东西
发表于 2011-3-10 14:40 | 只看该作者
平衡仪?多少钱?
发表于 2011-3-10 14:48 | 只看该作者
其实MB处于一个很尴尬的处境。当初为了不要电脑,加了很多led和三个电位器。现在又用电脑设置,就让这些东西显得多余了。另外,如果可以用电脑设置感度,那么究竟是听电脑的呢还是听电位器的呢,如果不能用电脑设置感度,设置软件又显得很没用。mb上的设置程序又占用了代码空间,对复杂的算法有一定的限制。
搞了半年才出来这么个软件,我想不是技术问题,而是思维问题。他们就没想明白到底该怎么搞。
发表于 2011-3-10 15:11 | 只看该作者
原帖由 hazy 于 2011-3-10 14:48 发表
其实MB处于一个很尴尬的处境。当初为了不要电脑,加了很多led和三个电位器。现在又用电脑设置,就让这些东西显得多余了。另外,如果可以用电脑设置感度,那么究竟是听电脑的呢还是听电位器的呢,如果不能用电脑设置感 ...
严重同意。。。。。。
发表于 2011-3-10 19:27 | 只看该作者
当初人家不用电脑调整的目的就是为了占领市场的一种方法。现在目的达到了,做进一步的升级,细化的设定就需要靠电脑来实现,合情合理。
市场占有率越大,后续固件的开发就有资金支持,性能一更新,就会有更多的老客户认同,自然就会吸引到新的买家。所以mb的前景还是很不错的。
[ 本帖最后由 井底蛙 于 2011-3-10 19:31 编辑 ]
发表于 2011-3-10 20:55 | 只看该作者
原帖由 neowu4 于 2011-3-10 07:39 PM 发表
电位器在外场调节就很方便和直观~接上PC只是为了在装机时一些设置选项更为方便~错过了不用从头来过~
总之各有各的优点~也不能一概而论~
而且在PC端设置好了。并意味着在飞行时就是这个感度等等。。还是会通 ...
电脑端是调用户自定义的细化参数,或者说是高级功能。
也不是每个用户都必须设定的。
发表于 2011-3-10 20:58 | 只看该作者
另外,目前软件还没推出。
也不能肯定只是2个功能调整~还是等软件出来再下判断吧。
发表于 2011-3-11 08:39 | 只看该作者
:em26:
发表于 2011-3-11 11:37 | 只看该作者
SK720就是通过PC设定的,没有MB上那么多LED和电位器。
发表于 2011-3-11 12:23 | 只看该作者
原帖由 井底蛙 于 2011-3-10 19:27 发表
市场占有率越大,后续固件的开发就有资金支持,性能一更新,就会有更多 ...
mb占领市场的主要办法是低价,你让他卖到2000快一个,看看还有人买不?
不用电脑调整,我不觉得比用电脑调整来的简单,为了能看到那几个灯和调那几个电位器,花了我多少心思来布线啊,累到吐血。相反,如果有外置的设置卡或者无线模块,要比现在的方式好得多。
现在看来,mb颇有点作茧自缚的感觉。机上调整是鸡肋,食之无味,弃之可惜。
发表于 2011-3-11 12:49 | 只看该作者
不论单轴或三轴,场外只管用调节合是较好的,体积可更小,但如V8那个小蛋要舵缧的1/3价有多的,就没意议了,PC是细调升级必需的,固件能支援日後升级便行,MB还是个不错的选择,期待日後加上定速功能,那更爽:em15: :em15:
发表于 2011-3-12 12:52 | 只看该作者
:em00:
发表于 2011-3-12 13:11 | 只看该作者
mb多钱?
