Specifications:
Nominal voltage: 3.3V
Nominal capacity: 4.4Ah
Power:
Nanophosphate is a positive electrode material of remarkable rate capability, critical to high power systems. Our high power products are able to pulse at discharge rates as high as 100C and deliver superior power by weight or volume in a cost effective solution. With their low impedance and thermally conductive design, A123 high power cells can be continuously discharged at a 35C rate, a marked improvement over other rechargeable battery alternatives, and have consistent power over wide state of charge (SOC) range.
Life:
A123’s Nanophosphate technology delivers exceptional calendar and cycle life. At low rates our cells can deliver thousands of cycles at 100% depth of discharge (DOD), a feat unmatched by most commercial lithium ion cells. Even when cycled at 10C discharge rates, our cells deliver in excess of 1,000 full DOD cycles. Not only does A123’s technology retain its energy, it also retains its power capability. |
