查看: 4556|回复: 10
一日本摸友的无刷无传感器电机驱动方案
发表于 2004-10-5 12:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
无刷风扇电机驱动电路
无刷无传感器电机驱动电路
无刷无传感器电机驱动源代码(1)
;**** A P P L I C A T I O N   N O T E   A V R  ************************
;* Title:                Brush-less Sensor-less DC motor speed control
;* Version:                1.2
;* Last Updated:        02.12.20
;*                        v1.2 Bug found at maximum power control. ZL timer loop counter made no-power out timing.
;*                        v1.1 Correct the Low-voltage sense level and add the off timing for photo coupler delay compensation.
;* Target:                AT90S2313 10MHz
;* Author:                Takao Shimizu
;* Support E-mail:        shimizutko@nttdata.co.jp, tel:+81-3-3533-9377
;* DESCRIPTION                This program is for model airplane Brush-less/Sensor-less DC Hi-Power motor control with usual
;*                        digital proportional radio control interface.
;*                        Also, this program has low-voltage sensing, no-signal sensing with keep-run timer(400mS) and
;*                        no-signal fail safe function.
;*                        One AT90S2313 can handle all interface lines to drive power FETS, rotor sensing, low voltage and
;*                        radio connection.
;*                        To discuss this program's detail, system hardware schematic is required.
;*                        Applications are model airplane, boat, hybrid car, home appliance's motor control ...etc.
.equ        phase_repeat =128        ;Starting repeat time data in TIMER0 interrupt routine.max 255 (Slowest starting speed)
.equ        duty_max =240                ;on-duty timing at maximum power. max. 255
.equ        phase_max =4                ;phase timing at maximum speed. frame frq.=CLK/1/256(40kHz)/this value. Consider sampling law.
.equ        start_on_duty =64        ;used output on-duty timing routine at starting-up 1 phase only. off_duty=255-(start_on_duty). max. 255
;These values is slightly longer by interrupt machine cycles
.equ        uS800=125        ;too short. 900uS/6.4uS T1 control input pulse width measuring resolution
.equ        uS1100=173        ;1250uS/6.4uS T1 control input pulse width measuring resolution
.equ        uS1900L=296-255        ;1900uS/6.4uS T1 control input pulse width measuring resolution
.equ        uS2200=343        ;too long. 2200uS/6.4uS T1 control input pulse width measuring resolution
.equ        uS2200L=343-255        ;too long. 2200uS/6.4uS T1 lo byte control input pulse width measuring resolution
.equ        hys_hi=20        ;hysterisis threshold hi-level of duty data to avoid jitter at starting control input data
.equ        hys_lo=10        ; hysterisis threshold lo-level of duty data to avoid jitter at starting control input data
.DSEG                        ;Start data segment
.ORG 0x60                ;Set SRAM address to hex 60
RAM_DUTY:        .byte 1        ; storage for motor power control duty data
ph_count:         .byte 1        ;phase timing repeat counter for starting slow 3-phase sweep frequency generator
temp0:                .byte 1        ;general scratch space. used mainly in TIM0 data setting.
temp3:                .byte 1        ;general scratch space
correct_pulse_width: .byte 1        ;flag to test control input pulse width. 0:incorrect, 1:correct
RAM_TCNT1H:         .byte 1        ;Temp storage space for T1 hi-byte timer data
RAM_TCNT1L:         .byte 1        ;Temp storage space for T1 lo-byte timer data
RAM_SHORT:         .byte 1        ;motor off control pulse width data from T1 lo-byte timer data
RAM_LONG:         .byte 1        ;full motor power control pulse width data from T1 lo-byte timer data
RAM_SENSE:        .byte 1        ;sensor data storage space to check very slow rotation
RAM_POT:        .byte 1        ;Storage for roundtime loop counter data storage space to check very slow rotation
RAM_HYS:        .byte 1        ;slow stick position jitter cancel hysterisis data storage
;***** Registers used by all programs
;******Global variables used by routines
.def        temp        =r16        ;general scratch space
.def        temp1        =r17        ;Mostly used for motor drive pattern. In sound gen. rtoutine, used for general scratch space,
.def        temp2        =r18        ;general scratch space, used in INT1 interrupt routine. Do not care the using temp in T1 interrupt.
.def        stack        =r19        ;store SREG space for interrupt
.def        on_time        =r20        ;on-duty timing data register
.def        r_sense        =r21        ;get rotate data from sensors and store here
.def        timset        =r22        ;Flag for timer over flow
.def        phase_tim_count =r23        ;motor phase timing counter
.def        duty_time =r24        ;Duty time setting register for timer0
;XL is used as scratch space
;XH is used as scratch space
;YH is used argument in each sub-routine
 楼主| 发表于 2004-10-5 12:42 | 只看该作者
;**************** motor speed control start routine ********************
start_up_setting:        clr on_time                ;initial power must be 0
                        ldi temp,hys_hi                ;avoid jitter of control input data
                        sts RAM_HYS,temp        ;by setting the slow speed hysterisis
                        ret
output_on_timer:
set_off_check:                cpi on_time,0                ;Control off?
                        breq free_run_tim
set_on_timer:                mov duty_time,on_time
                        com duty_time                ;on_time=$FF-(on_time) until overflow
                        out TCNT0,duty_time
st_pulse_out:                rcall P_FET_on_fast
                        out PORTB,temp1                ;Turn on/off the U,V,W Output transistor
                        clr timset                ;Clear timer0 flag
watch_tim_over:                sbrs timset,0                ;Skip here if timer0 overflow is occurred
                        rjmp watch_tim_over
free_run_tim:
set_off_timer:        rcall P_FET_off_fast
                out TCNT0,duty_time        ;Do not confuse. off-timing is on_time data, until over flow!
tim_set:        clr timset                ;Clear timer0 timeover flag
off_phase:        sbrs timset,0                ;Skip if timer0 overflow is occurred
                rjmp off_phase
get_sense:        in r_sense,PIND
                andi r_sense,0b00000111        ;get rotate data from sensor circuit
                ret
P_FET_off_fast:                in temp,PORTB                ;Turn of all of output FET with photo cuppler delay compasation
                        andi temp,0b01010111        ;Turn off setting for the UP,VP,WP P-site Output FETs
Pch_deley:                out PORTB,temp                ;'02/01/11 Photo cupller delay compensation, 2uS for Toshiba TLP521
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        clr temp
                        out PORTB,temp                ;
                ret
P_FET_on_fast:                mov temp,temp1                ;Turn of all of output FET with photo cuppler delay compasation
                        andi temp,0b10101011        ;Turn off setting for the UP,VP,WP P-site Output FETs
                        out PORTB,temp                ;'02/01/17 Photo cupller delay compensation, 2uS for Toshiba TLP521
                        out PORTB,temp                ;Turn on the UP,VP,WP P-site Output FETs
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp
                        out PORTB,temp1                ;Output FETs all off for brake point test
                ret
;*** Reset handler ***
;*** to provide initial port, timer and interrupt setting up
Reset_handler:        clr temp
                out PORTB,temp                ;Output FETs all off
                ser temp                ;set register temp=R16 to "11111111"
                out DDRB,temp                ;initialize port B as all Outputs
                ldi temp,0x00                ;clear temp
                out DDRD,temp                ;initialize portD as all Inputs
                ;Timer0 internal clock divide for output motor switching duty resolution
                ldi temp,(1<<CS00)                ;CLK/1
                ;ldi temp,(1<<CS01)                ;CLK/8
                ;ldi temp,(1<<CS01)+(1<<CS00)        ;CLK/64
                ;ldi temp,(1<<CS02)                ;CLK/256
                out TCCR0,temp
                ;Disable Timer0 overflow interrupt for output duty power control initialize
                ldi temp,(0<<TOIE0)
                out TIMSK,temp
                ;Timer1 Timer/Counter1 Control ResisterA(TCCR1A)
                clr temp                        ;no output on pin15(OC1), Off the PWM operation
                out TCCR1A,temp
                ;Timer1 internal clock divide for input power control digital prop. pulse width measuring
                ;Also, Input Timer1 counts data capture Edge select is "Falling Edge" by ICES1="0"
                ;ldi temp,(1<<CS10)                ;CLK/1
                ;ldi temp,(1<<CS11)                ;CLK/8
                ;ldi temp,(1<<CS11)+(1<<CS10)+(1<<ICNC1)+(0<<ICES1) ;CLK/64, 6.4uS resolution + Noise canceller for pin11 ICP
                ldi temp,(1<<CS11)+(1<<CS10)+(0<<ICNC1)+(0<<ICES1) ;CLK/64, 6.4uS resolution
                ;ldi temp,(1<<CS12)                ;CLK/256
                ;ldi temp,(1<<CS10)+(1<<CS12)        ;CLK/1024
                ;ldi temp,(1<<CS11)+(1<<CS12)        ;EXT pin T1, falling edge
                ;ldi temp,(1<<CS11)+(1<<CS10)+(1<<CS12)        ;EXT pin T1, rising edge
                 out TCCR1B,temp
                ;Interrupt input setting for digital prop. pulse input
                ;ldi temp,(1<<ISC11)                ;the falling edge of INT1 generates IRQ1
                ldi temp,(1<<ISC11)+(1<<ISC10)        ;the rising edge of INT1 generates IRQ1
                out MCUCR,temp
                ldi temp,(1<<INT1)
                out GIMSK,temp                ;Enable INT1 interrupt for Digital Prop. input line
                ret
get_control_pulse:
                rcall single_beep        ;initial powered sound
                rcall pulse_in_test        ;wait the one sample of control pulse. Possibly noise when TX powered.
                        rcall pulse_width_check
                        lds temp,correct_pulse_width         ;test control input pulse width by this flag. 0:incorrect, 1:correct
                        cpi temp,1                        ;correct?
                        brne get_control_pulse                ;No. incorrect
                ret
get_shortest_pulse: rcall wait_2sec
                rcall get_T1_data
store_short_pulse:
                lds temp,RAM_TCNT1H        ;get T1 hi byte data
                cpi temp,0
                brne get_shortest_pulse        ;short not enough
                lds temp,RAM_TCNT1L        ;Get motor off control pulse width
                        clc
                        cpi temp,uS1100                ;Shorter than 1100uS?
                        brsh get_shortest_pulse        ;short not enough
                        cpi temp,uS800                ;Shorter than 800uS?
                        brmi get_shortest_pulse        ;Too short
                inc temp                ;get digital 1 digit margin
                inc temp                ;get trim 1 digit margin
                inc temp                ;get 1 digit margin
                        cpi temp,0x81                ;RAM_SHORT must be more than $80 to avoid more than 8 bit subtract calculate
                sts RAM_SHORT,temp        ;Store motor off control pulse width data
                rcall po_pi
                ret
get_longest_pulse:rcall wait_2sec
                rcall wait_2sec
                ;rcall pulse_width_check
                rcall get_T1_data
store_long_pulse:
                cpi temp,1
                brne get_longest_pulse        ;long not enough
                lds temp,RAM_TCNT1L        ;Get motor full power control pulse width
                cpi temp,uS1900L        ;longer than 1900uS?
                brmi get_longest_pulse        ;long not enough
                clc
                cpi temp,uS2200L        ;longer than 2200uS?
                brsh get_longest_pulse        ;Too long
                ;brpl get_longest_pulse        ;Too long
                dec temp                ;get digital 1 digit margin
                dec temp                ;get trim 1 digit margin
                sts RAM_LONG,temp        ;Store motor full power control pulse width data
                rcall po_pi
                rcall po_pi
                ret
get_motor_off_pulse: rcall wait_2sec
                brne get_motor_off_pulse        ;No. incorrect
                cpi temp,0
                brne get_motor_off_pulse        ;Is the TX stick position motor_off?
                lds ZH,RAM_SHORT        ;ZH is used as just temporary register
                clc
                cp temp,ZH                ;Is the TX stick motor off position?
                ;brpl get_motor_off_pulse        ;short not enough
                brsh get_motor_off_pulse        ;short not enough
                rcall po_pi
                rcall po_pi
                rcall po_pi
                ret
no_signal_check:in r_sense,PIND                ;
                andi r_sense,0b01000000        ;get digital prop. input pulse on pin11(PD6)
                mov XH,r_sense                ;HX is just scratch
                ;brne sense_lo_batt        ;pulse is "H", then should not read T1 Timer/Counter
                        in temp,TCNT1L                ;get T1 law lo-byte timer data from T1 timer
                        in temp,TCNT1H                ;get T1 law hi-byte timer data from T1 timer
                in r_sense,PIND                ;
                cp XH,r_sense
                breq mS400_check
                brpl continue_run        ;ignore the data at "H" to "L" falling edge of T1 capture timing as spec. says
mS400_check:        clc
                cpi temp,0xfe                ;no-signal over 6.4uS * 255 * 255 = 400mS?
                brsh braking                ;stop the motor
continue_run:        ldi YH,0xa
                ret
braking:        ldi YH,0xb
                ret
brake_out:        ldi temp,0b01010100        ;motor Brake out
                out PORTB,temp
                ret
 楼主| 发表于 2004-10-5 12:45 | 只看该作者
sense_lo_batt:        in temp,PIND                ;
                andi temp,0b00100000        ;get power voltage comparator input on pin9(PD5)
                breq get_rx_pulse_        ;
about_50mS_tim:        ldi temp,0                ;motor free run
                out PORTB,temp
re_check_it:        in temp,PIND                ;
really_low:        ldi temp,0                ;motor free run
                out PORTB,temp
re_start1:        ldi phase_tim_count,phase_repeat ;Set starting 3 phase slow frequency
                sts ph_count,phase_tim_count
                ldi temp,255
wait_a_few_sec:
                dec temp                ;may 3-5 second
                brne wait_a_few_sec
                rcall single_beep
final_test:        in temp,PIND                ;
                brne final_test
                rcall single_beep                ;ready go
check_stick_off:rcall get_rx_pulse
                cpi on_time,0                ;is the stick position power-off?
                brne check_stick_off
get_rx_pulse_:        ret
;*** This routine catches the rotor position data
sense_rotor_position:
                ldi temp,(1<<TOIE0)        ;Enable Timer0 overflow interrupt for output duty power control
                out TIMSK,temp
;normal_timing:        rcall set_off_timer        ;IMPORTANT! wait a little time to compensate sensor circuit response time
;                rcall set_off_timer
;reduce_timing:        rcall set_off_timer        ;Whole control timing must be adjusted here and consider power limit
                ldi temp,(0<<TOIE0)        ;Disable Timer0 overflow interrupt for output duty power control
                out TIMSK,temp
duty_setting:                lds temp,RAM_duty
                        clc
                        cp on_time,temp
                        brsh set_control_duty         ;Branch if same or higher
                        inc on_time                ;Accelate with step by step to limit power current
                        rjmp check_max_duty
set_control_duty:        ;dec on_time                ;**************************
                        mov on_time,temp        ;De-accelerate immediately
check_max_duty:                clc
                        cpi on_time,duty_max        ;power limiter
                        brsh set_duty_limit
                        rjmp dec_phase_tim
set_duty_limit:                ldi on_time,duty_max
dec_phase_tim:                lds temp,RAM_POT        ;'02/02/16
                        cp temp1,temp                ;RAM_POT has previous rotor control data(temp1)
                        breq same_position        ;Rotor position is not rotated, then keep the power timing control
                        sts RAM_POT,temp1
                        dec phase_tim_count        ;sampling speed up(reduce the Timer0 frame timing) step by step
same_position:                clc
                        cpi phase_tim_count,phase_max
                        brsh keep_speed
                        ldi phase_tim_count,phase_max
keep_speed:                ret
get_rx_pulse:                rcall pulse_width_check
                        brne noise_detect                ;No. incorrect
                        cpi temp,0
                        breq slow_pulse                ;Is the TX stick position slow?
hi_pulse:                                lds temp,RAM_TCNT1L
                                        lds ZH,RAM_LONG                ;ZH is used as just temporary register
                                        clc
                                        cp temp,ZH                ;Is the TX stick motor full on position?
                                        brsh max_power
                                        lds ZH,RAM_SHORT        ;get minimum pulse width
                                        com ZH                        ;-(minimum pulse width)
                                        lds temp,RAM_TCNT1L
                                        add temp,ZH                ;+input pulse width= value of duty data
                                        brmi max_power                ;data will be x2 by "lsl"
                                        rjmp set_on_duty
                                        ;lsl temp
                                        ;sts RAM_DUTY,temp
noise_detect:                ret                        ;
slow_pulse:                lds temp,RAM_TCNT1L        ;
                        lds ZH,RAM_SHORT        ;Get motor off control pulse width
                        sub temp,ZH                ;Is the TX stick motor off position?
                        brmi motor_off
                        breq motor_off
set_on_duty:                        lsr temp                ;erase one digit jitter
                                lsl temp
;***** this routine makes hysterisis at starting only to avoid very slow start-up sequence
hysterisis_set:                ;**************************
                        ;ldi temp,30                ;TEST ONLY
debug:                                lds ZH,RAM_HYS
                                clc
                                cp temp,ZH
                                brsh set_hys_lo
set_hys_hi:                        ldi ZH,hys_hi
                                sts RAM_HYS,ZH                ;hysterisis threshold to avoid jitter of control input data
                                ;rjmp set_duty
                                rjmp motor_off
set_hys_lo:                        ldi ZH,hys_lo
                                rjmp slow_run
slow_run:
set_duty:                lsl temp
                        sts RAM_DUTY,temp
                        ret
motor_off:                clr on_time
                        sts RAM_DUTY,on_time
                        ret
max_power:                ldi temp,0xff
                        sts RAM_DUTY,temp
                        ;ldi on_time,0xff        ;test only
                        ret
pulse_width_check: rcall get_T1_data
                lds temp,RAM_TCNT1H
                cpi temp,0x01                ;Check the longest in-put control data.
                breq long_pulse_test        ;over 1.63mS?
                cpi temp,0
                breq short_pulse_test        ;less than 0.8mS?
                rjmp wait_control_in         ;too long incorrect pulse width(over 2.3mS)
long_pulse_test: lds temp,RAM_TCNT1L         ;get input power control pulse width low-byte data from INT1
                clc
                cpi temp,uS2200L        ;Check over 2200uS long in-put control data.
                ;cpi temp,0x30                ;Check the longest in-put control data.
                ;brpl wait_control_in         ;too long incorrect pulse width(over 2.3mS)
                brsh wait_control_in         ;too long incorrect pulse width(over 2.3mS)
                rjmp OK_input
short_pulse_test:lds temp,RAM_TCNT1L         ;get input power control pulse width low-byte data from INT1
                cpi temp,uS800                ;too short incorrect pulse width(less than 0.9mS)?
                ;cpi temp,0xA0                ;too short incorrect pulse width(less than 0.9mS)?
                brmi wait_control_in         ;bad data
OK_input:        ldi temp,1
                sts correct_pulse_width,temp ;OK. set "OK" Flag to RUN
                ret
wait_control_in:clr temp
                sts correct_pulse_width,temp ;Incorrect pulse width measured. Set bad Flag
                ret
get_T1_data:        in temp,PIND                ;This routine gets the pulse width counter(T1) capture register data
                andi temp,0b01000000        ;get digital prop. input pulse on pin11(PD6)
                brne input_hi                ;avoid data up-date by falling edge of PD6 as chatter
                ;interrupt handle routine        ;Disable all interrupts to avoid T1 up-date chattering
                in temp,ICR1L                ;get T1 timer data from T1 capture register
                sts RAM_TCNT1L,temp        ;Store to the RAM space to calculate
                in temp,ICR1H                ;get input power control pulse width hi-byte data from T1
                sts RAM_TCNT1H,temp        ;Store to the RAM space to calculate
                                         ;enable all interrupts
input_hi:        ret
wait_2sec:        ldi temp,80                ;register r_sense can be used in no-rotation mode.
wait_80_frame:        rcall pulse_in_test        ;wait about 2 sec. by number of sampling control input pulse frame
                dec temp
                brne wait_80_frame
                ret
pulse_in_test:        in r_sense,PIND                ;This routine checks the pulse width counter(T1)
                breq pulse_in_test
input_1:        in r_sense,PIND
                brne input_1
input_0:        nop                        ;ensure the ICP T1 capture time
                ;clr temp
                ;out PORTB,temp                ;Output FETs all off for brake point test only
                ret                        ;get falling edge of input pulse, Then SEE the T1 latched data
single_beep:        ldi temp,50                ;Set Sound freq.
beep_0:                sts temp3,temp                ;Store into the sound freq. data space
                ldi temp,30                ;beeping timer setting
beep1b:                sts RAM_SENSE,temp
                rcall beep_on
                lds temp,RAM_SENSE
                dec temp
                brne beep1b
                ret
w_beep:                rcall single_beep
                ldi temp,100                ;silence timer setting
silence:        sts RAM_SENSE,temp
                        clr temp
                        rcall silent
                lds temp,RAM_SENSE
                dec temp
                brne silence
                rcall single_beep
                ret
po_pi:                rcall single_beep
                ldi temp,20
                rcall silent
                ldi temp,40        ;"pi" freq. data
                rcall beep_0
                ret
beep_on:                        ldi temp1,0b01100000        ;Turn the UN,        VP,        W-off Output transistor
                                out PORTB,temp1                ;Turn on/off the UN,        VP,        W Output transistor
                                rcall little_timer
                                ldi temp1,0b10000100        ;Turn the UP,        V-off,        WN Output transistor
                                rcall little_timer
                                ldi temp1,0b00011000        ;Turn the U-off,VN,        WP Output transistor
                                rcall little_timer
                                ldi temp1,0b10010000        ;Turn the UP,        VN,        WP-off Output transistor
                                rcall little_timer
                                ldi temp1,0b00100100        ;Turn the U-off,VP,        WN Output transistor
                                rcall little_timer
                                ldi temp1,0b01001000        ;Turn the UN,        V-off,        WP Output transistor
                                rcall little_timer
                        rcall silent
                ret
silent:                        clr temp1                ;Turn off the U,        VP,        W Output transistor
                        out PORTB,temp1
                        lds temp1,temp3                ;beep off-duty timer data to reduce the waste current.
no_tone:                        rcall little_timer
                                rcall little_timer
                                rcall little_timer
                                rcall little_timer
                        dec temp1
                        brne no_tone
                        ret
little_timer:                        lds temp,temp3                ;Sound on Freq. data
beep_on_tim:                        dec temp
                                brne beep_on_tim
                                ret
 楼主| 发表于 2004-10-5 13:00 | 只看该作者
我试制过,电路没问题,程序中须将输入转子位置值取反,以便与输出代码匹配.在转速小于12000转时,表现良好,原设计主要用于直驱
 楼主| 发表于 2004-10-5 13:07 | 只看该作者
电路中场效应管桥臂驱动可由IR2101代替(可不用光藕),六个MOS管均为N沟道.若用P+N对管则可用CPU直接推动
发表于 2004-10-5 19:46 | 只看该作者
一点都有不明白,高人做几个给大家分分
发表于 2004-10-6 19:39 | 只看该作者
天才  在 2004-10-5 07:46 PM 发表:
一点都有不明白,高人做几个给大家分分
天才都说不明白了,那我这个玉米棒子就不搀和啦:em15::em15:
这念头还是新兵厉害呀:em26:
发表于 2004-10-6 20:43 | 只看该作者
一点都有不明白,高人做几个给大家分分
9494!:em05::em06:
发表于 2004-10-7 18:00 | 只看该作者
了不起,老兄是在哪找到的?图看不清楚,能将全套资料(或原始网址)发一份给我吗?fengqi@bnchina.com   谢谢
发表于 2004-10-8 18:02 | 只看该作者
第二张图看不清楚是因为网页把它缩小了,目前无点击打开新窗口功能,不过将它另存后就会变大了。
