集成图传接收机没有任何辐射。
肥鲨我看过一阵子,给你点建议
5.8G与国内的5.8G图传都不兼容。
不过你的1.2G转发办法有不少人在用了,没问题
Attitude其他方面都不错,但是视角好像是35度吧,而且不是玻璃透镜(或者什么特别的透镜),据说边缘比较模糊,不够清楚。
Dominator就是不能调瞳距,其他方面都不错。包括透镜,视角好像是40度的。
最近说要出DominatorHD,分辨率高了,800*600,视角45度的。可调瞳距,自带DVR,头追,接收机。
价格好像是360刀,记得在哪里看到过一个各版本对比的pdf文档。
如果佩戴舒适的话,真是绝配。我决定等这个了。
这是fpvlab上的一个进度帖,看起来至少等到年底。。。
I took the liberty of starting the 2013 thread so I can make a summary of the products:
New products for 2013:
DominatorHD - Beta release Oct 2013, limited release Nov/Dec 2013, full production widespread availability in March 2014
600TVL FPV Tuned CMOS camera - released
Trinity head tracker with pan/tilt/roll - released July 2013 as beta testing
PilotHD (720p 30fps mini FPV HD camera with AV out).- released with TeleporterV3 bundle, available separately Dec 2013
TeleporterV3 - released - QVGA display, 250mW TX and PilotHD camera for about $200 USD
Pan/tilt/roll - estimate 4th quarter 2013
Information on the DominatorHD:
There has been repeated questions on why the DominatorHD uses SVGA panels when the video link is only standard. Here are the reasons:
1) The goggles have HDMI in and support HD in. They can connect to a computer and display full SVGA graphics.
2) Large FOV desired: In order to acheive a wide FOV with low distortion, it needed the largest size LCD panel available. The existing VGA panels are 0.26" and 0.35". The SVGA panel is 0.44".
3) Minimize screen door effect: The SVGA panels utilize latest silicon wafer technology and are able to acheive a higher pixel density over the previous generation 0.44" VGA panels. Thus when the display is enlarged, the pixel grid is less noticeable over a similar FOV VGA display.
4) Smoother pixel transistions: This ties into 3) the extra pixels allow the display to render lines more smoothly where in a VGA lines appear more jagged.
DominatorHD development updates - latest update: 10/08/2013:
1st article shells: received
2nd article shells: received and approved 10/08/2013
1st delivery lens: received
DVR board 1st article: complete
DVR software 1st edition: as of 10/08 not seen.
LCD driver 1st article: complete
LCD driver software change: still waiting
