查看: 4493|回复: 16
gopro hero 4 预告
发表于 2013-10-13 04:16 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ambarella A9 Chip (GoPro HERO4) Feature Summary
  • 4K @ 30 frames per second
  • 1080p @ 120 frames per second
  • 720p @ 240 frames per second
  • Burst image capture – Sixty 12MP images per second
  • 1GHz Dual Core ARM Cortex
GoPro has not yet announced whether or not they will release a GoPro HERO4. However, the maker of the System on Chip (SoC) on board the GoPro, has released the all new A9 SoC. The Ambarella A9 chip boasts some very exciting upgrades to the current A7 chip that can be found on theGoPro HERO3 Black Edition. In case you were not aware, theGoPro HERO3 Black Edition is capable of 4K @ 15 frames per second, 2.7K @ 30 frames per second, 1080p @ 60 frames per second, 720p @ 120 frames per second, and WVGA mode @ 240 frames per second.
Ambarella A9 Block Diagram
The A9 chip supports the same video modes as the A7 chip in the HERO3 Black Edition, except it will be capable of higher frame rates. What I am really curious about is what the maximum frames per second will be with the A9 chip. The highest frame rate the A7 could achieve was 240 frames per second in the WVGA mode (less than 720p quality). Since it seems that the frame rates have been doubled in the new chip, it’s almost safe to say the A9 will support 480 frames per second in WVGA mode. That should allow for some sweet slow-mo videos.
Now that companies figured out how to release consumer cameras capable of capturing 4K at a smooth frame rate, and at a decent price, how will we make use of it?
When I got my first HD camera back in 2007, I was amazed by the quality and it was in no way comparable to my old SD DV camera. I eventually came to the point where I wanted to edit some video. I had the DellXPS Generation 3, it had a Pentium 4 Prescott 2.4GHz hyper threaded CPU, 2 GB of RAM and I have no clue what the video card was. I was usingAdobe Premiere Pro 2.0 to edit my videos. Back then I didn’t know much about editing and exporting HD, I mean how much could you know it was new. I eventually had my first edit complete, and I wanted to burn my exported HD footage to DVD. Big FAIL. You can’t burn HD onto DVD. I then finally realized I would need a HD DVD burner or Blu-Ray burner. Cha ching, they were over $1,000! I gave up on trying to burn my videos, and uploaded to YouTube. Back then YouTube didn’t support HD, ahhhh. HD cameras was a great technology released at a stage where it was hard to play it back, but are we in the same position today with 4K?
(3+价格较高,手上有狗的,可以等四出了再入吧,黑狗才是真谛~~)
发表于 2013-10-16 12:03 | 只看该作者
立体摄像的狗啊!!!看来又要花银子了!
发表于 2013-10-16 16:41 | 只看该作者
符合国人折腾的性格,有的是票子。
 楼主| 发表于 2013-10-16 17:07 | 只看该作者
折腾不折腾是部分人的爱好,跟国人没联系。
发表于 2013-10-16 17:41 | 只看该作者
好,,,买不起
发表于 2013-10-16 19:52 | 只看该作者
PS水平不够高啊
发表于 2013-10-16 23:56 | 只看该作者
我看是PS的。。。
发表于 2013-10-18 22:14 | 只看该作者
等着狗6出来
发表于 2013-10-18 23:40 | 只看该作者
经典第四代产品。要费米啦。
只是不要和IPHONE 一样到第五代只能通过颜色去吸引眼球就好了
发表于 2013-10-19 20:56 | 只看该作者
出来就买 毫不犹豫!
发表于 2013-10-21 10:06 | 只看该作者
期待实体的到来。。。
发表于 2013-10-23 21:12 | 只看该作者
这个PS的图片 P的有点。。。
发表于 2013-10-24 07:32 | 只看该作者
路过
发表于 2013-11-17 15:28 | 只看该作者
折腾折腾
发表于 2013-12-9 21:59 | 只看该作者
假的,3+的壳子比3的小,包括镜头螺丝改到里边,难道4又回归到3的壳子水平?
发表于 2013-12-9 22:31 | 只看该作者
狗4啊
发表于 2013-12-9 22:32 | 只看该作者
老新闻了,假的
