查看: 59|回复: 0
2014第五届中国无人机大会暨展览--参观记录
发表于 2014-9-19 14:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
点击查看详情
展会时间:20149162014918.
地点:中国国际展览中心8A馆(北 京)
废话不说,直击展会
中航工业“翼龙”I无人机系统
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg
另外一款机型:
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg
VD200垂直起降无人机系统
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image006.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image008.jpg
中航工业直升机
这款机型,绝对是展会的一个亮点,外形设计美观,漂亮,旁边还有2个小型的模型,第一眼看上去感觉是技术指标请看下图
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image010.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image012.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image014.jpg
接下来是个大头:总参六十所。这次展会各家规模来看就是60所最大,机型多,种类多,数量大。
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image016.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image018.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image020.jpg
下面这个东东,各位肯定见过:
(沈飞的)
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image022.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image024.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image026.jpg
还有个特殊机型,感觉是仿日本的哪个球形飞行器:
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image028.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image030.jpg file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image032.jpg
航测的:
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image034.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image036.jpg
西工大也不缺席:
(这个估计好多人见过)
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image038.jpg
南航的:
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image040.jpgfile:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image042.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image044.jpg
各位,仁者见仁,智者见智吧。不多说。
接下来看看这次展会的赢家:
DJI file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image046.jpg
代理在宣传。
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image048.jpg
一个民用无人机公司在“宣传
T-Motor
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image050.jpg
下面这几个就是都是用的T-Motor 电机
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image052.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image054.jpg
最后在来几张其他的把,没记住名字
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image056.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image058.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image060.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image062.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image064.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image066.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image068.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image070.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image072.jpg
